Ye everything else works fine, I checked everything...just those 3(clock, camera, and trip reset) components...also very curious as to why the trip resets everytime the ignition starts
---------- Post added at 09:13 PM ---------- Previous post was at 08:22 PM ----------
found this on infinitifx.org :"Today I had the same problem, I went to Advanced Auto Parts to purchase a new battery on my 2005 FX35 and after the guy changed it, my clock, reverse camera, and turn signals from inside did not work. The guy swore he connected everything back and there is nothing else he can do as Advanced Auto Parts is not a service center so immediately i went to Pep Boys and the mechanic there said whoever worked on your car left the harness and fuse loose (fuse box by the VDC switch in driver side) and all he did was pop it back in and walla it all worked again! I went back to Advanced Auto Parts and show them them the receipt and the work the Pep Boys mechanic did and now Advanced Auto Parts will be compensating me for the service charge at Pep Boys since they did not correctly install the battery. Whew! did a whole lotta running around but I'm glad it was a simple fuse fix and getting that service charge money back.
Will check tomorrow if that is the solution. I'll go back to them hopefully they'll reimburse the service charge
