Back windows
I'm having problems with my 2007 infinity fx35 back wondoew not lifting to close
Typical. Probably a switch, did you try using the one in the back seat, or just on the driver’s side door?
Damn switches just die after a while.:confused: Some times it’ll work if you use them both together?!
I have the same issue with using the front switch have to close the rear windows with rear door switches. Need to get around to replacing switches.
