R Robert Arreguin Member Car 2007 infinity fx35 Name Robert Feb 5, 2019 #1 I'm having problems with my 2007 infinity fx35 back wondoew not lifting to close
Old Blue Member Car FX 37 rwd Name Tom Feb 6, 2019 #2 Robert Arreguin said: I'm having problems with my 2007 infinity fx35 back wondoew not lifting to close Click to expand... Typical. Probably a switch, did you try using the one in the back seat, or just on the driver’s side door? Damn switches just die after a while. Some times it’ll work if you use them both together?!
MTN FX Mountain Man Premium Car 2004 FX35 AWD Name John Green Feb 8, 2019 #3 Old Blue said: Typical. Probably a switch, did you try using the one in the back seat, or just on the driver’s side door? Damn switches just die after a while. Some times it’ll work if you use them both together?! Click to expand... I have the same issue with using the front switch have to close the rear windows with rear door switches. Need to get around to replacing switches.
