QX70 09+ Akebono help needed on 2009 fx35
Discussion in 'QX70 Exterior' started by Lokey1971, Jun 12, 2018.
  1. Lokey1971
    Lokey1971 Member
    8
    2
    Folsom CA
    Car:
    2009 FX35
    Name:
    Brandon Lee
    Hi, Can someone help me confirm that I don’t or do need brackets to run this setup on my 2009 FX35. The dealership where I bought the calipers said they will bolt right on. Stoptech said they would and I see kits for sale that say they do. Then I see other owners saying they won’t. I would like to tear down my car this week and knock it out if it is just a bolt on and only have to cut the dust shield/backing plates. Don’t want to take the car apart is I really do need more parts.
    JonFull2015QX70 likes this.
  2. Kanedean
    Kanedean Premium Member Premium
    335
    34
    Peace River, AB
    Car:
    2013 FX37 AWD
    Yes, Akebonos made for the FX50 will bolt directly on. However, you will need new brake lines, specifically the banjo bolts from the lines to the calipers.
  3. OP
    Lokey1971
    Lokey1971 Member
    8
    2
    Folsom CA
    Car:
    2009 FX35
    Name:
    Brandon Lee
  4. OP
    Lokey1971
    Lokey1971 Member
    8
    2
    Folsom CA
    Car:
    2009 FX35
    Name:
    Brandon Lee
    I
    Thank you for the info. I was buying a ss line kit for an fx50 off of eBay and the seller refunded me my money because all these sites that selll this kit says you can you your stock lines. He wanted me to buy lines for my fx35 not a fx50s. So has off right now I have no lines and no brake hardware. Any suggestions where I might get the correct parts. Or what to ask for so it correct.
  5. 6T9CHGR
    6T9CHGR Member
    201
    41
    SINY
    Car:
    2012 FX35 LE
    Name:
    Chris
    You can use stock rubber lines. I am running them on the front of mine. I bought the SS lines from Stop tech but couldn't get the fronts to fit correctly...I think they are made for a 1st gen. The rear SS lines fit with no problem.
    You will have to get shorter banjo bolts. I got mine from from Search - Concept Z Performance
    on my '12 I had to cut eh rear as well as the front dust shields. Some say the fronts might not be necessary to cut but mine were....other than those things its a direct swap
  6. OP
    Lokey1971
    Lokey1971 Member
    8
    2
    Folsom CA
    Car:
    2009 FX35
    Name:
    Brandon Lee
  7. OP
    Lokey1971
    Lokey1971 Member
    8
    2
    Folsom CA
    Car:
    2009 FX35
    Name:
    Brandon Lee
    0341A14C-0C8A-4E96-B372-518ABF095353.png Thank you for the info and taking the time to respond. I’m going to try and install everything on Friday. Only need to figure out what brake pads I want to run. I just order some all chrome custom Asanti wheels and want to try and keep them clean, but I am also putting in a supercharger so need this bad boy to stop. Has anyone tried this SS brake lines?
  8. OP
    Lokey1971
    Lokey1971 Member
    8
    2
    Folsom CA
    Car:
    2009 FX35
    Name:
    Brandon Lee
    Thanks I ordered the the Bango bolts and the SS brake line kit from concept Z bango boots showed up just waiting on there lines. They should be here by Wednesday. Hope they fit. They sold me the techna-fit lines
    6T9CHGR likes this.
  9. DatMan
    DatMan Member
    694
    138
    Ottawa, ON
    Car:
    2007 FX35 AWD
    Name:
    Dat
    I think these are the same Banjo Bolts needed for the FX50 BBK Retrofit on a 1st Gen?
