Air bag light on dash flashing..help!
I have a icon flashing on my dash with a man sitting in a seat with the air bag blowing up in his face flashing red. Can someone please tell me what may be the cause of this ? Also how can i get off of my dash from flashing ?
You do have a search bar ya know
Ecu reset, Acc. pedeal release pos., Throttle closed pos., Idle air volume learn - InfinitiScene.com
ecu got nothing to do with srs, flashing means trouble is present, do any work to the fx recently? gotta get it scanned to see what the fault is...
If you just want to reset the light you can do this procedure I found on the Org
This is in reference to the little red airbag/seatbelt light -- the one that is in the middle of the gauges between the speedo and the RPMs.
Thanks to Ak1nza and bradical for finding this information.
HOW TO STOP THE AIRBAG LIGHT FROM BLINKING
1. Turn ignition switch from OFF to ON.
2. Within 1 second after air bag warning lamp is on for 7 seconds and turns off, turn off ignition switch.
3. After ignition switch is turned off, wait for more than 3 seconds.
4. Repeat steps 1-3 two more times (3 OFF to ON sequences in total)
5. Turn ignition switch to ON.
6. Turn ignition switch OFF and wait for more than 1 second then turn it back ON.
The blinking airbag light should stop.
If you just accidentally tripped the system you shouldn't have any more trouble. If there is a real problem with the airbag system the light will return.
You can always bring it to the dealer, especially if it's stock. Airbag lights are all under warranty, and it doesn't take more than 15 minutes to do. Had that problem on my TSX, that solved it.
yeah ive only had my 09 for a few months, and the air bag light flashes, as well as the "passanger side airbag" light blinks as well, will this fix it?
my closest dealer is 8 hours awayy lol
Just gave it a try, and i think that pretty much fixed the problem. i will test drive it later on to see if it came back on.. (prick fingers)
yeah, yesterday I think I was dazed or something, cause I got it the other way around... flashing means there was a problem that set a code but it's NOT current... solid light is current...
Now that I think of it I think you were right the first time. Well, flashing or not, you should get the code read so you can diagnose what caused, or is causing, the warning light.
By any chance did you recently change the in cabin air filter. If your not carefull with the harness that's in there you can cause an airbag warning light.
yeah, now I'm not sure either way tbh. wonder if it was a steady flash or flashing a code, I know I have a fault in mine & the light is steady... I would think maybe it wasn't current if it turned off after the reset, otherwise it woulda popped right back on...
Just had this happen to me this morning...
I just installed 2 12 inch Absolute Subwoofers and amp..
the AirBag light is also flashig..
I will try what was previously posted and see if it works.
wow - two 12's for your best of Menudo cd?
let us know what happens with the lights
HA...
No I am rocking the new Jackie Chan PoP CD from China... It rocks..
ha ha:laugh::laugh::laugh:
I will post pics up when the rain stops...
Please don't post pics....I don't want to see the hack jobs they do in South Gate ! :laugh:
did you do the reset? airbag light off now?
You should know... you worked on it with that gimp hand of yours... ha ha
:laugh::laugh::laugh::laugh:
Have not had time to reset and work on it..I will try to get to it tonight...
---------- Post added at 11:19 AM ---------- Previous post was at 11:19 AM ----------
"AND I'LL FORM THE HEAD"
VOLTRON Kicks ASSS..
