Well I took the time this weekend to finally upgrade the entire exterior and interior Lighting.
I replaces the entire interior with LED lights, High Beams to LED's and DTRL to LED to match the 6K, Rear LED Turn Signals, Reverser Lights and License Plate Lights.
When I finished the Install two things were not right. The Air Bag light was flashing on the Dash and the switch for the sunroof partially works. The sunroof will still open, but only if I keep pressing on and off to make it either open or close about 2 inches at a time.
I checked all of my fuses and everything is OK and I double checked my connections from the sunroof switch and all of the connections are fine since I had to remove the console to replace the dome lights.
Just don't know what to look for.
Any help would be appreciated.
