Air Bag Light Flashes / Sunroof Swith partially functional
HumbertoCALI
Premium Member
Premium
South Gate, CA
2003 FX45 AWD
Well I took the time this weekend to finally upgrade the entire exterior and interior Lighting.
I replaces the entire interior with LED lights, High Beams to LED's and DTRL to LED to match the 6K, Rear LED Turn Signals, Reverser Lights and License Plate Lights.
When I finished the Install two things were not right. The Air Bag light was flashing on the Dash and the switch for the sunroof partially works. The sunroof will still open, but only if I keep pressing on and off to make it either open or close about 2 inches at a time.
I checked all of my fuses and everything is OK and I double checked my connections from the sunroof switch and all of the connections are fine since I had to remove the console to replace the dome lights.
Just don't know what to look for.
Any help would be appreciated.
Taking a stab in the dark, did you try resetting the air bag lights or resetting the ecu? Wondering if it has anything to do with the airbag on/off indicator that is located in the top console, maybe you supplied power to the car while the wires were disconnected creating some kind of error to the passenger airbag indicator. If the reset doesn't work, recheck the wires.
Try this:
https://www.infinitiscene.com/forum/showpost.php?p=9479&postcount=1
Airbag SRS Light Reset.
1. Turn ignition switch to the "ON" position (Do not start the vehicle).
2. All cluster lights will come on (Diagnostic Mode).
3. As soon as the Airbag light turns off, switch the car off. (Be sure to turn the ignition switch off before the airbag light starts flashing).
4. Repeat steps 1-3 (2) more times and the flashing light should stay off.
I'll try it when I get it back from the shop.
Dropped it off for some little details that need to be fixed.
This just sucks when I drive it and the light keeps flashing on me.. UGhgh.
