illestFX35
- Los Angeles/Glendale
- 2010 FX35 RWD
Not a great pic (just took the car off the jack so it's high) but that's 20x10.5" STR 607 front and back. Front is +35 w/ 25mm spacer so +10 and rear is +20 w/ 15mm spacer so +5.
This is ride height
I would not get the 9" width, the concavity is determined by wheel width. 9" will be very flat face. I don't know if the 10.5" width comes in +30, I thought it was +20 or +35. A +35 fits in the front just fine. I'm swapping spacers soon to go more aggressive, going to +5 in front and +0 in rear. Right now at my offsets, the rims poke but I stretched the tire so it doesn't rub. If you run normal sized tires, I think the +35 in front would be fine. +20 in rear would rub unless you roll/flatten your fenders. My rear fenders are modded and so are the fronts.
---------- Post added at 09:29 AM ---------- Previous post was at 09:25 AM ----------
This is the old setup 22" TSW Jarama's 9" front +5 (w/ spacer) and 10.5" in rear +25. 265/40/22 in front and 295/35/22 in rear. I liked the look, but rubbed non stop even after doing everything short of pulling the fenders. The rubbing is more a function of ride height though, if you have just springs, no rub.
i was looking into this setup 22x10.5 all around. has anyone done this on a 2nd gen? I want to see what they look like. ill try to ps it today.
