AC high pressure pipe leak
WietseFX35
Netherlands
2009 FX50S AWD
Hey guys,
Today i noticed my climate control started to fail.
After a good check i found out that one high pressure pipe is leaking.
For some strange reason it came out of the original position and after the swaybar from the window wipers has been rubbing against it untill it finally went completly trough the pipe causing a leak.....:frown:
Now i have been looking for a part number or some kind of reference about this pipe so i can order a new one, but the only thing i can find is that it is called "High pressure pipe 2" in the manual.
This is the one that is connected next to the brake booster/ABS pump going to the connection that leaves the engine bay and goes inside the interior to the climate unit under the dash.
Does any of you guys have a part number for me or can tell me if this same pipe is used on a 350Z or Murano so maybe i even can order it trough the nissan dealer.
Any help is appreciated.....it's hot in Holland at the moment :tonguey:
