5zigen Gravis
Can someone please photochop these on an FX?
I'm getting mixed opinions. I think it'll make the wheels bigger than 20s due to the spoke design, but it does look really simple in design..
That's very nice
so 20x9.5 with +35 offset all around should be a perfect fit for our FX? I suppose this would make the wheels concave in a bit? Would +45 offset make it less concave?
What tires size would work?
They will be as soon as they clear remaining inventory. Pretty cheap since they are discontinuing.
God forbid something happens to your wheels and they need replacing, that's the only problem I see with discontinued wheels. Hot wheels tho .. :top::top:
I think the +45 (EXTEND an extra 14mm) would be better +35 might rub (EXTEND an extra 24mm), a +40 wold be ideal (extra 19mm) also I wonder if the TPMS will fit in there.
which offset would have the most 'concave' effect? I like concave.:laugh:
+25 will be fine depending on the tire. Generally with the concave type wheels the lower the offset, the more the face is designed to be concave.
+45 will be more tucked than +25, +45 refers to the measured distance from the centerline of the wheel to the mounting point. Remember 0 offset is dead center of the wheel. On a 10" wide wheel that's 5" in both directions. -25 means 6" out 4" in and vice versa. mm is a smaller measurement and works better in reality than using something +5/32 or +1" which is what +25 is. :biggrin:
Clear as mud? :rofl:
So I convinced my wife.... I think I'm gonna purchase it.
I wonder if Z1 can give me a better price???
I'm still confused on the offset thing... I always get confused with this offset thing. So it sounds like +45 offset and +38 offset will work either way, but +38 will push the wheel further out and +45 will be a bit tucked in. I should be OK with inner clearance on both of these offsets, right?
What tire size would u guys recommend for each offset? Wider would be preferable and I am lowered on H&R
I placed my order with Z1 today. Kwame was able to give me a pretty competitive price. These wheels are not TPMS compatible according Kwame.
Now, I just need to order tires.
Which tires size should I be ordering? I would like to purchase Yokohama Prada-X
295/45, 285/45, 275/45??
Help would be appreciated.
