360 view camera failure.
Geek8ter
Surrey Hills, UK
2015 AWD QX70 S Premium
David
I have a 2015 QX70d S Premium with all the options. Last week my cameras stopped working. I have ran diagnostics and have some screen shots of the results. Has anyone else has similar failures? Everything else works, parking sensors, Bluetooth, reverse lights and sonar just the camera button is dead and they don't come on when reverse is engaged. I have a part number of 3GW5A listed in the diagnostic check. I have a bad feeling about this as that part is the best part of 1000 bucs and I still have to fit it. If it's a design fault it's a case for Infiniti to help out but without other examples of failure I will struggle to argue. 20191229_135353.jpg 20191229_135107.jpg 20191229_135353.jpg 20191229_135107.jpg 20191229_135353.jpg 20191229_134236.jpg 20191229_135107.jpg
have you already fixed it? did you replace a part or could it be repaired ?
Hey there,
I took it into the Infiniti to confirm the part and cause of failure. Water ingress can cause those units to fail.
Infiniti confirmed it was the AV COMM module and that water had not caused it.
I didn't buy the new part as the car was off the road for a car park rub and then the lock down. As soon as the weather started heating up the cameras started working again.
I spoke to Infiniti who were really helpful and they thought it could be a dry joint on the board within the module. Their service manager said that if it was his car he'd have the unit taken out and have an electronics engineer look at it. It would cost around 200 instead of 1000.
It will be interesting to see if it fails again when the winter comes.
If you want to take the AV COMM unit out it's under the left hand front seat (drivers seat in the US) it's the size of a cigarette packet. The car will still run and drive without it fitted. It's not a Nissan controller as are many Infiniti parts and instead runs on it's own software. You'll need a good electronics engineer to look at the board solders to find the bad joints.
Hope you get it sorted.
D.
[QUOTE = "Geek8ter, post: 1382554, membro: 14915"] Ehi,
L'ho portato negli Infiniti per confermare la parte e la causa del fallimento. L'ingresso di acqua può causare il fallimento di tali unità.
Infiniti ha confermato che si trattava del modulo AV COMM e che l'acqua non lo aveva causato.
Non ho comprato la parte nuova perché la macchina era fuori strada per uno sfregamento del parcheggio e poi il blocco verso il basso. Non appena il tempo ha iniziato a scaldarsi, le telecamere hanno ripreso a funzionare.
Ho parlato con Infiniti, che sono stati davvero utili e hanno pensato che potesse essere un giunto secco sulla scheda all'interno del modulo. Il loro responsabile del servizio ha detto che se fosse stata la sua auto, avrebbe fatto fuoriuscire l'unità e avrebbe guardato un ingegnere elettronico. Costerebbe circa 200 invece di 1000.
Sarà interessante vedere se fallirà di nuovo quando arriva l'inverno.
Se si desidera estrarre l'unità AV COMM, si trova sotto il sedile anteriore sinistro (sedile del conducente negli Stati Uniti) delle dimensioni di un pacchetto di sigarette. L'auto continuerà a funzionare e guidare senza essere montata. Non è un controller Nissan come molte parti Infiniti e funziona invece sul suo software. Avrai bisogno di un buon ingegnere elettronico per esaminare le saldature delle schede per trovare le articolazioni difettose.
Spero che tu lo abbia risolto.
D. [/ Quote]
anche a me' di colpo non vedo piu' nulla sul monitor quando metto la retromarcia ( qx70 diesel con 90.000 km del 2014 ) o schiaccio il pulsante delle telecamere' , centro infiniti di milano mi hanno detto partita la centralina costo 1000\1500 euro !!!! che sfortuna
Hey Butrym,
The part was over £1000 ($US1250) so I didn't bother. A few months later it started working again.
I have spoken to a few guys at Infiniti that say if it was theirs they would take the unit out and have it tested for loose connections or dry solders. They think I could have it repaired for a fraction of the replacement cost.
It's still working and i think there is a correlation to the weather. Rain or damp conditions make it malfunction.
You can still drive the car with no issues if you take the unit out. It is found on left hand side of the car under the front seat. Passenger side UK, driverside US.
Good luck.
[QUOTE = "Geek8ter, post: 1382890, membro: 14915"] Hey Butrym,
La parte era oltre £ 1000 ($ US1250), quindi non mi sono preoccupato. Alcuni mesi dopo ha ripreso a funzionare.
Ho parlato con alcuni ragazzi di Infiniti che hanno detto che se fosse loro avrebbero portato fuori l'unità e l'avrebbero testata per connessioni allentate o saldature a secco. Pensano che avrei potuto ripararlo per una frazione del costo di sostituzione.
Funziona ancora e penso che ci sia una correlazione con il tempo. Le condizioni di pioggia o umidità lo rendono malfunzionante.
È ancora possibile guidare l'auto senza problemi se si toglie l'unità. Si trova sul lato sinistro della macchina sotto il sedile anteriore. Passenger side UK, lato guidatore USA.
Buona fortuna. [/ PREVENTIVO]
no perche comunque i sensori funzionano e non ho problemi se non ho la telecamera !!! daltronde a spendere 1000 oltre euro mi sembra eccessivo !!
