3.7L 2nd gen FX custom exhaust?
Discussion in 'QX70 Engine & Drivetrain' started by veritas, Mar 28, 2017.
  1. veritas
    veritas Member
    31
    8
    Los Angeles 818/213
    2013 FX37
    I have a few questions for an aftermarket exhaust..
    Currently have a 2013 FX37 with resonated test pipes but everything else is stock.
    The shop I go to quoted me $250 installed for a custom axleback/muffler delete with magnaflow tips. The thing is, he said it's not stainless steel, it would be aluminized steel but lifetime warranty..
    1. Would you guys recommend that route or should I get a G37 Manzo axleback and get it extended? Concerned about the sound/quality difference
    2. How would it work for the 2nd gen FX if I wanted to go true dual?
    3. Is any G37/370z catback exhaust full bolt on onto the FX? I know the tips have to be extended but besides that.
    Thanks in advance!
  2. shadow191
    shadow191 Premium Member Premium
    4,077
    310
    Atlanta, GA
    2007 FX35
    I'd get something with a muffler as you already have test pipes. No muffler is going to be loud and probably raspy. If you get a catback, the G37 needs extended tips but the 370Z might need the exhaust extended as well as tips.
  3. DatMan
    DatMan Member
    496
    85
    Ottawa, ON
    2007 FX35 AWD
    Dat
    Have you checked the ARK catback setup yet?
    PEEJ likes this.
  4. akachi
    akachi Member
    295
    61
    NY Queens
    2011 FX35 AWD
    Matt
    I had the G37 Tanabe axleback which is similar to the Manzo axleback. The tips had to be extended
    Here's how it sounds. Everything else is stock
    JayCSmoov likes this.
  5. Old Blue
    Old Blue Member
    218
    36
    Spring TX
    FX 37 rwd
    Tom
    Borla makes a nice flow through muffler with the 1,000,000 mile warranty, finally made my FX 37 sound like a boy's car.
    I had to have a muffler shop install it, but it looks pretty cool, so sweet
  6. Luis Gutierrez
    Luis Gutierrez Member
    24
    20
    San antonio,tx
    2009 fx35
    Luis
    I recently just bought some top speed ebay mufflers for a g37 and they fit just fine. All the hangars match perfect.I'm also running a beluga y pipe and it really opens it up and has a deeper growl. I had to add roughly about 4 inches of pipe to get the tips to where they need to be. It sounds great and isn't too loud or raspy at all. The dual setup should fit just have to extend the tips as well. If you want detailed pics with measurements let me know
    demi6ix likes this.
  7. Old Blue
    Old Blue Member
    218
    36
    Spring TX
    FX 37 rwd
    Tom
    I wondered about using a G 37 exhaust but nobody in the exhaust industry seemed to know,
  8. Luis Gutierrez
    24
    20
    San antonio,tx
    2009 fx35
    Luis
    I spent around 300 bucks total I believe . Those cheap Ebay mufflers aren't bad at all. I'm not building a race car it's just for sound and looks. I'll take pics when I get home of what I did .
    Old Blue and demi6ix like this.
  9. Old Blue
    Old Blue Member
    218
    36
    Spring TX
    FX 37 rwd
    Tom
    Yeah, I just had to do something about that factory exhaust, my first GEN sounded much better.
  10. milu
    milu Member
    46
    21
    Uk
    Fx50s
    Does the g37 set up fit the 50s too?
  11. Luis Gutierrez
    24
    20
    San antonio,tx
    2009 fx35
    Luis
    I don't see why it wouldn't. Everything is the same besides a few changes to the body. I'm sure it's still running the same setup.
  12. Luis Gutierrez
    24
    20
    San antonio,tx
    2009 fx35
    Luis
    So I just measured and you have to add 4 inches to get it to where the stock tips stick out to.
    KO843030 likes this.
  13. KO843030
    KO843030 Member
    7
    3
    Charlotte, NC
    2011 G37x
    Kyle
    Hey guys, I have a 2011 G37x with a FI catback and Z1 HFCs. Any idea if they'd both work on an FX50? About to sell the G to a buddy and get an FX37/50. Leaning towards a 50. :)
    **IF it'll work, I assume it would require some cutting/welding, which I'm fine with.
    Luis Gutierrez likes this.
  14. Luis Gutierrez
    24
    20
    San antonio,tx
    2009 fx35
    Luis
  15. Luis Gutierrez
    24
    20
    San antonio,tx
    2009 fx35
    Luis
    And also I know this might not be related to the exhaust but the g37 upper strut tower brace works with the 2nd gen fx35 with no problem. Really helped out with stability. 20170409_122034.jpg
    demi6ix and KO843030 like this.
  16. Luis Gutierrez
    24
    20
    San antonio,tx
    2009 fx35
    Luis
    I'm also running a beluga y pipe that is the same as the g37
  17. KO843030
    KO843030 Member
    7
    3
    Charlotte, NC
    2011 G37x
    Kyle
    Oh yeah?? Nice! I have the Cusco strut tower brace. Good to hear the Y pipe works too, so my entire catback should.
    However, I'm leaning more towards an FX50...any idea if the same things should be true?
    demi6ix likes this.
  18. Luis Gutierrez
    24
    20
    San antonio,tx
    2009 fx35
    Luis
    I want to say they are running the same chassis setup so I think it will. Shoot if anything just take some measurements of an fx35 and 50 and compare them. I'm sure know one would mind if you peaked under one before you bought it . As far as the cat back goes I think the mid pipe might need to be extended as well. Not entirely sure though. If anything I can measure my mid pipe for you and you can see if it will work
  19. KO843030
    KO843030 Member
    7
    3
    Charlotte, NC
    2011 G37x
    Kyle
    I'm sure the brace would work fine with a 50, but wondering about the catback hookingup to the cats, if I kept the stock cats. I think all the measurements and whatnot would be perfect, just the flange to flange of CBE to cats.
  20. Luis Gutierrez
    24
    20
    San antonio,tx
    2009 fx35
    Luis
    They would probably work. If not it wouldn't be much work to weld on new flanges to match.
