jasonadams74
- United States
- fx35
I've flipped tires before. Directional doesn't matter, they will rotate in same direction. Only tires you can't flip are side specific ones like the Nitto Invo I have on my BMW. They have grooves that are specific to left/right. Most independent tire shops will flip anything, larger chains may not.
Yes like these crappy Nittos 420s. They say outside on the tire, he needs to run either Yokahama paradas or Toyo Proxies STll so you can flip the tires. Good luck with your search and yeah go for it!
I used to rub just slightly on the rears with +25 offset. Just trimmed the plastic back with a dremel from the inside. 285/40/22
Sent from my iPad
