20x10 offset 25mm rim fit my 2010 FX35?
AB_FX35
My friend is giving me a great deal on his last set of brand new 20" Avarus rim 20" by 10" wide. 5-114.3 bolt pattern. 25 mm offset.
will this offset OK for my 2010 FX35 with no spacer?
Is it OK to run tire size 295-45-20 all around?
I really like the flush look and do not like the tire sticking out of the fender look
I need a quick answer so I can tell him to keep the rim for me or not.
thanks for all your help
Compared to my set up you will stick out another 20mm all around..this will result in a 10 mm or more poke in the front and a slight poke in the rear..I'm running 265-40-22 +30 on 22x9 and am flush up front and a slight 5-10mm tuck in the back..
I take that the 25mm offset is way too low for my FX35
so I changed my mind and ordered a set XXR 526 20x9 offset 35mm and 295-45-20 tires all around, the wheels and tires should be here in a week or so :top:
the +25 mm will make them just stick out barely. i have 22x10.5 w/ +35 offset which is just equivaelent to a +30mm offset if it was just a 10" wide wheel
