2011 Fx35 AWD Shuddering only during tight turns?
Topper Harley
Vancouver
2011 FX 35 V6
Topper
Hello Group I have a problem that I hope you guys have seen and fixed,
Our 2011 FX35 "Shudders" or "Stutters" when turning tight corners at low speed. It almost feels like my old 4x4 suv when I tried to make tight turns while 4x4 was full engaged....
It doesn't shudder when the car is cold, only does it when car and tranny is warmed up after 15/20 min......then If I let it sit for hour or so, it can make the tight turns without shuddering again?>?>?>?>?>?
Weird, going straight and reverse is fine even at high speed.........Only the tight turning forward and reverse at very slow speeds.....
Have you guys seen this and repaired the issue ?
This sounds like a CV axle problem. Does the problem happen when turning both left and right, or just in one direction.
[QUOTE="Denis McGuire, post: 13856
It shudders during tight turns left and right ; same issue forward and reverse.
Doesn’t happen when car is “cold” turns without issue no shuddering.
Only after 20/30 min of driving if we try and make tight turn it shudders.
wide turns and straight driving , No shuddering.
