2010 Paddle Shifters
Took Apart my 2010 FX35 AWD today and gave me confirmation that we are NOT pre-wired for them :tdown:. We do, however, have the mounts for them though. Here are some pics that i took.
This is a pic taken from the bottom looking up at the harness.
Heres the left and right side mounts.
I could of told you that myself without you tearing the steering shells apart. Ofcourse there are pre mounts for the paddles. The FX50 has optional paddle shifters that's why. The steering column on the FX35 is the same as the FX50.
And knowing Infiniti very well, they usually never leave something pre-wired cause they would be losing money on leaving something pre-wired when there is no use for the wiring if the car doesn't have it.
Just added the paddle shifters to my 2010 FX35. The 2010's are not wired for this but if you run wires from the paddles to the harness where the wires should have been, everything will work just fine. Took me about 2 hours to carefully and neatly run 2 wires to the back of the AV unit and install the paddle shifters. Ill do a write up soon.
The paddles and steering column covers were purchased from Riverside Infiniti. Called and asked for paddle shifters from the FX50S and the cover kit for the steering column. They gave me a good deal, 240.00+tax shipped to me.
So many people will thank you for this :tup:
Very nice! You will love the shifters and its always good to have options on how you want to drive.
Install paddle shifters on 2010 FX35
Heres a quick write up on how to do it. Its not too detailed....Sorry guys. Don't have too much time on my hands.
1. Purchase Paddle shifters and Steering column cover from any Infiniti Dealer. (Riverside infiniti was cheapest for me and they included the hardware). Referance to the FX50 Sport when they ask for what car its from. Choose your color and Choose manual or mechanical Steering column.
2. Purchase some Jumper wires at your Electronics store. I bought mine at Frys. They come crimped and with shrink wrap on it.
(this is not the exact picture. This is just to give you an example) The ones at Frys come with shrink wrap, not the hard plastic.
3. Purchase extra wire to run from your steering column to the back of your AV unit.
4. Take apart your steering column covers and you will find the shifter mounts on each side.
5. Cut two of your jumper wires and insert one into each prong on your shifters. Then fill it with silicon to secure them. Let it dry and then mount onto your steering column.
6. Wiring is pretty easy. On each of the shifters, ground one wire. Doesn't matter which one. The last wire on each shifter will be ran to the back of the AV unit so go ahead and extend that wire making sure it will reach the back of the AV unit.
7. Take apart your Center Council and pull out the AV unit. At this time you can run the extended wires from the back of the dash to the AV unit itself. Make sure that the wires do not interfere with the steering column moving mechanism. You are gonna work with this harness behind the AV unit:
8. Cut one more of your Jumper wires and attach one to each end of the wires you extended. On each of the jumper wires removed the shrink wrap to reveal the metal crimp. This crimp will be inserted to the harness so it can make contact with the prong when plugged back into the unit.
By opening the harness the way i showed in the "Around View Camera Mod," i was able to insert the exposed jumper wire into the harness, close up the security tabs and plug it back into the AV unit and it worked just fine.
Once everything is done you can take a spin around and test it before putting everything back together.
Sorry for the lack of detail and or pictures. But this should give you a good idea on how to do it.
Just did this on my 10 fx35 with NAV, worked great.
sobi6111, you do not have to remove the steering wheel or airbag, as you turn the wheel right or left it will expose the screws that you need to remove. Thanks again Saleen
Hi I am interested in doing this mod also. Can anyone list the part numbers needed and what the proximate cost was?
I don't have part number available anymore but you can call and tell them you have any 09 FX50 Sport. They come with them from factory so they wont have problems finding the paddle shifters. Cost was around 300+
hey buddy. do u have photos of how it look like after? and by calling them. and mention about 09 fx50 sport. what are we going to get at that point? thanks
