2010 infiniti fx35 p0729
Philb
Pennsylvania
2010 infiniti fx35
Phil
Just starting off with my fx love it but having some trans issues.
Found a p0729 code in it I have 202k on the truck infiniti recommended drain and fill of trans fluid any input of someone that's had this?
No grinding but am Def experiencing some slipping and a jump I first especially on hard turns
Check to see that you have the correct amount of fluid. It can totally make a difference. If it is already, For sure try a drain and fill. Transmission is very sensitive to fluid levels. I have had a failed transmission already and chose to rebuild it. Reverse was the first to go for me. Coolant mixed with oil (a sometimes Nissan issue) and caused the bands inside to degrade. Once rebuilt, I separated that out to an external cooler. No problems since. Was expensive repair, but I wanted to keep the car.
gto's FX :: 2005 FX 35 RWD SPRT
