2009 - 2013 FX35 Rear Camber Fix with SPC Performance 72265 Camber Kit
Wow, I didn't know that there is no alignment adjustment can be made per FSM to front suspension on 2nd Gen. If the front alignment specs are off, it simply mean suspension parts are worn.
Per FSM, there is no differentiation in alignment adjustments among an 2wd, AWD, AWD with RAS. So pretty confident this will work for 50S as well. Remember the Plus steering is a separate system then the suspension. RAS is powered by a motor getting signal from the RAS control unit. It is mounted by the rear axle with a rod on each side push/pull on the knuckles.
Awesome! What a great find! Thank you Andy, really appreciate your practical knowledge of our rides. :good:
Can anyone confirm if this works with the fx50s and h&r lowered sport springs .. Please confirm I just ordered the springs
It worked with me with Eibach Springs but I think the H&R springs is little lower than the Eibach, so am anticipating some off spec but better than non [emoji5]️
Andy did this on my FX, but when I went to get an alignment done there was still negative camber but a little better than before so this doesn't fix it 100%. I wish I had my results to post up.
