2007 US spec FX35 OEM brake disc size?
sama156
Warsaw
Noob here.
Can somebody confirm: have the FX35 brake disc and pad sizes remained unchanged throughout the production '03-'08? I am in the process of sourcing replacements (possibly custom Nitrac discs) but I pumped into conflicting information on he front discs:
Diameter: 320
Height: 49mm
Thickness: 34mm OR 28mm <<<<<<
I was looking into some replacements and there seemed to be separate products offered for 2006 and earlier and 2006+ cars. In case of discs, the earlier cars had 28mm and later 34mm discs?
gen1 : 2003-2005 = thinner front rotors and 1 piston front caliper (& rears are identical)
gen1 : 2006-2008 = thicker front rotors and 2 floating pistons calipers (& rears are identical)
gen2 : 2009-2012 (non sports) = prob has the same front rotors and dual piston calipers as well (can say the same for rears).
Perfect, thanks!!!:top:
I know the front rotor part# is different. From 11/2002 - 11/2005 use part #40206-CG010 and from 11/2005 and up use part #40206-CL70A. Sorry don't know the specifics.
