2006 FX35
ruben alanis
texas
2006 fx35
ruben
2006 FX35 well taking care of, high mileage.
Yesterday got in ignition switch on to activate steering column and try to start engine and nothing happened, radio, dash lights, A/C comes ON but won't start, please any advise.....
Yep, sounds like a battery with a dead cell.
well i tried to jumped and nothing,
dashboard lights radio a/c everything comes ON but not a clicking sound or try to turn or start, if battery it should start, if starter at least it would click at starter area correct?
Next, I would disconnect the battery terminals, clean them and the posts, reconnect TIGHTLY and try again.
If no joy, next have your battery tested. If good, then you may have a bad starter.
well i bought a New Battery, had starter tested and no luck, still same.
removed side panel by fuse panel, removed fusses one by one to see if blown, All good, when turn switch to ignition I can hear/feel a click on box under fuse panel. if that helps, I am clueless what to do next.
Check starter, battery first!
i big thank you to those who pitched two cents and help with advise, at end baterie replaced then starter from Oreilleys, then a real Starter "new" not rebuild from Carquest and is Alive. Thank you...
