Was looking for this info, so I read the manual and just in case anybody else needs it.
Rims:
Lug Pattern: 5x114.3
Centerbore: 66.1mm
Lug Torque: 80ft/lbs
Type: Aluminum
Size: 18 x 8JJ
Offset: 47mm
Type: Aluminum
Size: 19 x 8-1/2JJ
Offset: 50mm
Spare 17 x 4T Offset: 30mm
Tires:
245/45/18
Pressure: 35psi
245/40/19
Pressure: 35psi
Spare: 145/80/17 Pressure: 60psi
Rims:
Centerbore: 66.1mm
Type: Aluminum
Size: 18 x 8JJ
Offset: 47mm
Type: Aluminum
Size: 19 x 8-1/2JJ
Offset: 50mm
Tires:
245/45/18
Pressure: 35psi
245/40/19
Pressure: 35psi
