2005 FX35 Engine Splash Guard Replacement
Das FX
Los Angeles
2005 FX35 RWD
Hi, how difficult is it to remove and replace the engine splash guard and replace (mine cracked)? Will I need to replace any additional parts (plastic screws..etc) and approximately how long will it take. I already have the new engine splash guard. The debate is to do it myself or just tell the dealer to. Instructions would be helpful if you recommend that I just do it. Please advise.
Not much to it. I think there are about 10 - 12 10 mm bolts. Just undo them and swap the splash guard out and re-install the bolts. Pretty sure there are no plastic screws or put pin.
So I do need to buy replacement screws? How long would you estimate it will take to do the replacement?
Depends if you have some rusted bolts and how quickly you can turn the ratchet :wink (2): I'll say 30 - 40 minutes.
