Not OP, but I can say it's not that bad. I'm on the max drop for BCs in front and rear (I've pulled the adjustment collar in rear for another 1/4") and the ride is the same as when the car was higher. Having said that, you will scrape all the time. I run smaller than OEM tires so my car is probably lower than OP's and I have to watch for big dips and speed bumps.
