2003-2008 Infiniti FX35/FX45 Wheel Studs
fxlr8
Staff
Administrator
What are wheel studs?
Wheel studs are threaded fasteners that are pressed into the wheel hubs, along with lug nuts they help secure the wheels to the vehicle.
Picture Definition:
2003-2008 Infiniti FX Factory Wheel Stud Specs:
Factory Part #: 43222-70T00
Thread Size: 12x1.25
Thread Length: 30MM
Knurl: .561 X 8mm
Wheel Stud Install Procedure:
Basic procedure on installing wheel studs
///91
Alternatives:
ARP
https://www.infinitiscene.com/search/1/?q=s...ght=arp+subaru
Wheel stud info from the links above:
Brand ARP
Manufacturer's Part Number 100-7716
Part Type Wheel Studs
Product Line ARP Wheel Studs
Summit Racing Part Number ARP-100-7716
UPC 672036033651
Wheel Stud Style Press-in
Wheel Stud Thread Size 12mm x 1.25 RH
Knurl Diameter (in.) 0.565 in.
Underhead Length (in) 3.000 in.
Knurl Length (in) 0.270 in.
Quick-Start Nose Yes
Quantity Sold as a set of 5.
Notes Designed to fit Subura WRX applications. Will fit untrimmed under stock 1st gen FX center caps with 20mm spacers and stock or open ended lug nuts.
Brand: H&R
Manufacturer's Part Number: 12253524
Part Type: Wheel Studs
Product Line: H&R Wheel Studs
Wheel Stud Style: Press-in
Wheel Stud Thread Size: 12mm x 1.25 RH
Knurl Diameter: 0.561 in.
Thread Length: 1.38 in.
Quantity: Sold as a set of 4
Notes:
Brand: H&R
Manufacturer's Part Number: 12254524
Thread Length: 1.77 in.
Notes:
just a suggested tweak to the arp specs, where it says :" Notes Designed to fit Subura WRX applications. Will fit untrimmed under stock 1st gen FX center caps with 20mm spacers. you should add to the end of that "and stock or open ended lug nuts" because they won't fit with 20mm spacers and most aftermarket closed lugnuts. I'll remove this post after
Done. Feel free to make that kind of change to any technical posts of mine in the future. :top:
...just don't mess with my bad jokes. :tongue (2):
Just referenced this fine thread and in my subsequent research I found a couple more options:
Brand -NISMO
Manufacturer's Part Number -40222-RS035
Part Type -Wheel Studs
Product Line -NISMO Wheel Studs
CZP Part Number -G35-40222-RS035
Wheel Stud Style -Press-in
Wheel Stud Thread Size -12mm x 1.25 RH
Knurl Diameter (in.) -0.565 in.
Underhead Length (mm) -50mm
Knurl Length (in) -0.270 in.
Quantity -Sold as a set of 10
Notes -They're $85...
Brand -NISMO
Manufacturer's Part Number -40222-RS045
CZP Part Number -G35-40222-RS045
Underhead Length (mm) -60mm
Notes -They're $130...
Just measured the OEM studs. The front studs are longer then the rear ones, because the front hub is thicker then the rear.
Front
Thread Length: 26mm
Rear
Thread Length: 23mm
