- Portland, OR
What is suspension?
The suspension system consists of the shocks/struts and springs in both the front and rear. Coil-over systems combine the shocks and springs into one assembly and usually include a certain level of adjustment (ride height, shock dampening force) not seen in the original configuration.
Picture Definition:
Front Spring/strut assembly:
Rear shock and spring assembly:
Front and Rear coil-over assemblies:
2003-2008 Infiniti FX Factory Suspension Specs:
Factory part numbers:
-FX35 (AWD)
--'03-'04
---Strut (left): 54303CG085
---Strut (right): 54302CG085
---Shocks (L&R) - 18" wheels: 56210CG025
---Shocks (L&R) - 20" wheels: 56210CG725
---Front springs: 54010CG108
---Rear springs: 55020CG206
--'05-'06
---Strut (left): 54302CL025
---Strut (right): 54302CL025
--'07-'08
---Strut (left): E4303CL01A
---Strut (right): E4302CL01A
---Shocks (L&R) - 18" wheels: E6210CL00J
---Shocks (L&R) - 20" wheels: E6210CL70J
-FX35 (RWD)
--'03-'04
---Strut (left):
---Strut (right):
---Front springs: 54010CG008
---Rear springs: 55020CG106
--'05-'06
---Strut (left):
---Strut (right):
---Shocks (L&R) - 18" wheels: 56210CL025
--'07-'08
---Strut (left):
---Strut (right):
-FX45
--'03-'06
---Strut (left): 54303CG725
---Strut (right): 54302CG725
---Shocks (L&R): 56210C725
---Front springs: 54010CG208
--'07-'08 w/out run-flat tires
---Strut (left): 54303CL00J
---Strut (right): 54302CL00J
---Shocks (L&R): E6210CL70J
--'07-'08 w/ run-flat tires
---Strut (left): 54303CL70J
---Strut (right): 54302CL70J
Service intervals:
-Shocks/Struts: 60K miles
-Springs: Lifetime
Suspension install Procedure:
Basic procedure for installing oem style struts/shocks and springs:
///7785
Basic procedure for installing Coil-over suspension
///9333
Alternatives:
KYB (shocks and struts):
Front Left mfg part #: 339056
Front right mfg part #: 339055
Rear left+right mfg part #: 349027
H&R (springs):
Sport spring kit mfg part #: 53043
Eibach (springs):
Sport spring kit mfg part #: 6366.540
BC Racing (coil-over kit):
Coil-over kit mfg part #: V-03
Megan Racing (coil-over kit):
Coil-over kit mfg part #: MR-CDK-IF03
Expected results from lowering options:
Drop Thread
Things to consider when converting to aftermarket suspension springs or coil-overs kits:
1) Re-calibrating the alignment and adjusting the camber and toe if necessary. If after realignment the camber or toe is still off oem spec and cannot be adjusted any further than you may have to look into purchasing aftermarket camber/toe kits.
2) Rubbing issues may occur once lower springs or coilovers are installed with the addition of aftermarket wheels/tires and/or use of spacers, which may lead to having the front and rear fenders rolled or shaved
Picture Definition:
-FX35 (AWD)
--'03-'04
--'05-'06
--'07-'08
-FX35 (RWD)
--'03-'04
---Strut (left):
---Strut (right):
--'05-'06
---Strut (left):
---Strut (right):
--'07-'08
---Strut (left):
---Strut (right):
-FX45
--'03-'06
Service intervals:
-Springs: Lifetime
///7785
///9333
Alternatives:
H&R (springs):
Eibach (springs):
Drop Thread
