2003-2008 FX Tail / Reverse Light Removal
I am having difficulty in step 4 while removing the tail light. I am not able to pull the light out after removing two 10mm bolts and don't want to use extra pressure to avoid damage to the light. what tools can I use to pull the light out from front where the snap on piece is ?
need to change my side marker bulb and don't want to pay the dealer $38 for changing the bulb.
No tool. You just have wiggle it with gentle pulling force way from the car.
HI,
I'm having an issue where all 3 studs seem to have stripped out in the plastic so I cant remove the nuts for the reverse light. I bought the new light and the parts guy at Infiniti told me this a common problem, yet I cant find any information on how mechanics go about removing them when this happens! From my online searches I would say if you provided this information you would be the "only one" on the internet to have done so! Any help would be much appreciated.
2003 FX35 AWD
Thank you,
Hans
Try to break the stub lose from the light or destroy the light from outside to get to the stud and break it lose since you bought new ones.
