08 fx35 daily
Welcome to IS....
58k - Purchased. 5/2008.
65k - Installed Strut Brace and upper and lower rear tie lateral braces.
66k- Replaced Cabin Air Filter with carbon activated.
75k - Installed H&R Springs and new KB Shocks, struts turned rotors, replaced brakes
80k - Replaced heater blower Assy.
89K - Replaced Oil Cooler O ring.
90k - Replaced engine belts.
98K - Replaced both front hub assemblies with bearings.
110k - Changed front and rear differential oil, changer transfer case oil.
115k - Changed Cabin Air Filter.
126k - Changed Radiator, thermostat, hoses, cap, coolant, trans fluid.
130k - Replaced Power Steering Pump.
138k - Changed Spark Plugs, Changed PCV valve, Cleaned Throttle body.
139,212 - Changed Oil and Filter
142k - Replaced right front hub assembly and brakes on all 4 wheels.
146k - Changed out right front CV Axle
146.2k - Changed Oil and filter
151k - Changed Oil and Filter
158k - Replaced Front drivers side CV Axle, 4 Wheel alignment, 4 new tires.
156k - ,;Changed Oil and Filter
160k - Changed Oil and Filter
165k - Changed Oil and Filter
165k - Replaced front driveshaft
170k - Replaced front tires
175k - Changed Oil and Filter
175k - Replaced Cabin air filter.
Oil Filter- K&N HP 1006(largest) or 1010
Oil- Mobil 1 5w/30w (5 1/8th quarts)
Spark Plugs- NGK Iridium IX LFR5AIX -11 4469
Tires - 265/65/18 Yokohama Geolander A/T G015
