05 FX OEM Sat receiver antenna?
Redlines
05 FX35 3.5L AWD
Mike
Hi just bought a 05 FX with Navi but no XM just says No Sat when Sat button is pressed.
Is this the OEM Sat antenna or would I have to add one?
My FX has the disc changer under the passenger seat. It's the Bose system so I assume the Bose amp is buried somewhere?
Can't seem to find where the OEM Sat receiver would be mounted or it's input cable it's not under the back seat. Need to add XM one way or another really would like to use the stock interface
Thanks for any help
I have seen that one it doesn't show where the 2005 is that factory manual is from a 2006 which has a different location. If you read the thread it states this
The FSM doesn't say where the sat unit would be but I believe it is stacked with the bose amp in the 05 model year. The antenna from your picture isn't for sat radio so unless you have a "shark fin" antenna toward the back of your roof you don't have a unit back there and may not be prewired for it in any case. You will have to wire in a sat unit and the antenna. You'll have to buy a harness to connect it to the back of your head unit.
Btw. the unit under your passenger seat is for your Disc based navigation system. Your CD changer is in the head unit.
