04 stock calipers
I have my complete 2006 stock brake system (front calipers, front pads, front lines, front rotors, rear calipers, rear pads, rear lines, rear rotors, rear knuckles). They weight in pretty heavy, so shipping will be costly and I'm in NYC. Are you only looking for 4 stock calipers? I have no idea how much they are valued for since I used them for only 2 years with ~10k miles, been running FX50 BBK's since.
Just some insight info, 2006 front stock set is a bit beefier than 2003-2005. So if you plan on retro fitting 2006-2008, you might need the complete fronts. Rears are unchanged.
Ebay/CL or local Junkyards are a good source too, check there.
I believe turbo said that the 06-08 was a direct bolt on for the 03-05, but as you said OP might need the entire set up.
If kidfx35 doesn't want the rear rotors let me know what you want for them.
Woooo, stock brake setup in hot demand? I have my complete stock brake setup with painted black calipers with almost new Akebono ProAct pads available too. :smile (2):
ill take good condition front stock rotors and never remachined
reason: to find out if my warped rotors are causing vibrations
Honestly, I don't remember if they warped or not. I wanted to say they're not. It's been in the basement for almost two years now. I'll have get you the measurement tomorrow.
Rotors are pretty heavy and shipping them wont make any sense. I bet you can find some Canadian FX'er parting out.
Sooner I'm from the NYC area I interested in the calipers if they are still available.
pm me and we can discuss since you are in nj. You might need 10 post counts to use the iS msg system. Are you looking for both front and rear calipers?
