Stereo Dash Kit
Yes Sir! Every place I took it to in So. Cali wanted to charge big bucks because many said it couldn't be done or it was going to be really expensive so I did some research and practiced on some old honda parts before attempting to do it on my FX. I took the stock panels on mine because it is the sport model and pulled off the aluminum skin to expose the ABS plastic. There are some holes in the factory panels from the ABS casting process that needed to be filled in and then a lot of sanding to smooth the surface for the carbon fiber.
View attachment 12307 View attachment 12308
Turned out very good. Do you mind posting a DIY guide for laying Carbon Fiber. I would like to try it one day. Thanks
Well I don't claim to be an expert by no means at laying carbon fiber, but I learned from watching the video below several times over and over and there's a show called, "How it's made - Dream cars" on Discovery channel that I recorded because they described in great detail how the Pagani Huayra carbon fiber panels are created which I found fascinating.
This mod is insane. The finish looks very good. You sure does have the patience and dedication.
Wow that looks complicated as hell :cry:. Thanks for posting!
