Power door locks dont work
molle200
sweden
Fx45
Mikael
Hi
Have a FX45 -03
Suddenly the power locks stop working.
The key "talks" to the car. I can roll down the windows by pressing the button for 3 sec and that works.
The power locks works when i use the metalick key in the door and when i press the button in the door panel.
Any idees?
MVH
Mikael from Sweden
Sounds like the door lock actuator going bad. Pretty common among the nissan/infiniti cirlce. Many threads on replacing it on this forum, g35driver, and my350z.
I used lock actuators from partsexpress with good results for 4 years now, but some will say use oem. I had to replace 3 of my doors already and its all custom work. Not hard if your handy with some tools and common sense. It'll start off by being weak, then complete failure, then the other doors will follow eventually.
Then it shuld be the one on the driver door i guss. That one shuld be the one that send the signals to the other ones. am i right?
(and i hope you do understan my weak english :wink:
nope its not the actuator. the powerlocks works perfekt whit the button on the driver side door panel and the metalic key. no one that have som good advise on where to begin?
Which door lock are you having problem with?
The driver door lock/actuator does not send signal to other door locks/actuators. The signal is from the BCM (Body Control Module). When the press the lock/unlock button on the driver door control unit, it sends signal through the BCM to the door you want to lock/unlock. If you use the remote to lock/unlock, the remote
Do you hear any noise/sound from the problem door when you use the renote to lock/unlock the door?
Not sure but it sounds like the OP is saying that the door actuators are working with the key just not the key fob if this is the case then maybe just need new battery in key fob.
#la_fx35
Its all doors. Non is working from the button on the key.
Nois? Yes i hade some problems with the trunk door this winter. sunded bad when it looked it. Sonded like the engine needed to work a little to hard.
But it sound like i have problems with the BMC i guss then.
That shuld get some fail code in the ODB.
#MTN FX
Cant be the key fob as it sends down the windows and i have 2 of them and non works for the door locks.
I mean any noise or sound at the door actuator when you use the remote fob to lock/unlock the car.
