Hey fellas - Wifes 05 FX35 I'm pretty sure has the infamous leaky cover. No oil underneath , but slight oil burn smell and loosing some oil. She is due for plugs so i want to do both at the same time. Is the any way to tell which side is leaking without taking everything off just to put it right back on to order the the part?
I did a search and it sounds as though you cannot use the old cover and buy a gasket to fix (???) If thats the case (hopefully not) where the best /cheapest place to buy everything? Thanks
