09+ FX35 RWD VDC/BRAKE/Slipping lights
illestFX35
Los Angeles/Glendale
2010 FX35 RWD
For the past couple days my car has had the VDC OFF, BRAKE, and Slipping lights come on simultaneously. My brakes are stock and I have Aftermarket wheels if that matters. I was thinking some kind of ABS sensor was the issue. Can anyone confirm this and do I need to take the FX to the dealer? After I turn my car off it goes away, but comes back on eventually.
With those combination of lights, I believe that your brake fluid level is too low. It's probably gone pass the minimum level mark of the brake fluid reservoir. I would top it off immediately before air gets in the master cylinder.
Same thing happened to me too recently. Might be the weather change? idk.
I know some vehicles require very specific types of fluids. Do any of you suggest a place to buy and which type of liquid to get?
I'm actually getting an oil change at the dealer on Thursday. Might buy it there if not too much.
I gave the owners manual a look.
It recommends the exact following:
http://www.amazon.com/Genuine-Nissa...rds=nissan+super+heavy+duty+brake+fluid+dot+3
I might just get that since it's a bit cheaper and all I'm probably going to have to do is top up the fluid. Plus I have amazon prime so free 2 day shipping.
I saw your link, price was cheaper than amazon for the liter but I didn't look into the shipping cost and transit time and I knew I wouldn't need that much. Thanks for the recommendation.
Your call.
Dot 4 is better than 3 and compatible. Higher boiling point.
This is a no brainer IMO for how much difference??
I wouldnt get caught on the track or anywhere hilly without it
---------- Post added at 01:59 PM ---------- Previous post was at 01:54 PM ----------
///11604[/ATTACH]
I have been putting this off for a while, seriously neglecting this issue but these lights keep coming on more often now.
I took a pic yesterday of the brake fluid reservoir and it looks like it's exactly in the middle. Car was off when I took the pic.
From what I've read, that's exactly where the fluid is supposed to be, right in the middle.
I do not mind buying $12 worth of brake fluid and adding a bit but I don't think I'm supposed to fill it up anymore so there is no point. What do you guys think?
Hm.. that's interesting.
While the engine is off, I usually fill the reservoir close the max limit.
When was the last time you replace the brake fluid?
