Cel after cai install....
I just installed a JWT pop charger and now my check engine light comes on and the code is for bank 2 sensor running lean. I was thinking maybe my ECU is still in the process of learning the new pop charger..? :bulgy-eyes:
did you turn on your car at somepoint when maf was disconnected? i would do a reset or clear the cel code and see if it comes back
No, I didn't turn it on until I was done. Yeah, I'll just reset it and see if it pops back on.
---------- Post added at 07:46 PM ---------- Previous post was at 11:27 AM ----------
Update: check engine light went off about 30 minutes into my next to drive. Not sure what caused it to pop on but hopefully it will stay off now.:good:
was likely just learning the new intake forcing more air into the mix aka making you run lean, so the CEL was accurate - the computer just hadn't made the fuel adjustments yet to compensate. Shouldn't come back up.
