From the image of the Yaw sensor location, it looks like the sensor is under the cup holders portion of the center console. Hope that helps! After reading more on that sensor, it seems like the 2wd and awd models have different yaw sensors. The 2wd model is a yaw rate/side G sensor and the awd one has that plus the decel G sensor. This procedure is for the decel G sensor so I guess thats only for the awd model. Not sure if yours is 2wd or awd but here is the procedure anyways:
CALIBRATION OF DECEL G-SENSOR (AWD MODEL)
NOTE: After removing/installing or replacing yaw rate/side/decel G-sensor, ABS actuator and electric unit (control unit), suspension components, or after adjusting wheel alignment make sure to calibrate of decel G- sensor before running vehicle.
CAUTION: To calibrate decel G-sensor, make sure to use CONSULT-II. (Adjustment cannot be done without CONSULT-II.)
1. Stop vehicle with front wheels in straight-ahead position.
CAUTION: • The work should be done at a horizontal place when vehicle is in the unloaded vehicle condition.
• Keep all tires inflated to correct pressures. Adjust the tire pressure to the specified pressure value.
2. Connect CONSULT-II and CONSULT-II CONVERTER to data link connector on vehicle, and turn ignition switch ON (do not start engine).
CAUTION: If CONSULT-II is used with no connection of CONSULT-II CONVERTER, malfunctions might be detected in self- diagnosis depending on control unit which carry out CAN communication.
3. Touch "ABS", "WORK SUPPORT" and "DECEL G-SEN CALIBRATION" on CONSULT-II
screen in this order. Refer to CONSULT-II BASIC OPERATION PROCEDURE.
4. Touch "START".
CAUTION: Set vehicle as shown in the display.
5. After approximately 10 seconds, touch "END". (After approximately 60 seconds, it ends automatically.)
6. Turn ignition switch OFF, then turn it ON again.
CAUTION: Be sure to carry out above operation.
7. Run vehicle with front wheels in straight-ahead position, then stop.
Fig. 7: CONSULT-II Display Decel G-Sen Calibration
Courtesy of NISSAN MOTOR CO., U.S.A.
8. Select "DATA MONITOR", "SELECTION FROM MENU", and "DECEL G-SEN" on
CONSULT-II screen. Then make sure "DECEL G-SEN" is within 0 +/-0.08 G. If value is more than specification, repeat steps 3 to 7.
9. Erase memory of ABS actuator and electric unit (control unit) and ECM.
10. Turn ignition switch OFF.
