teemoney
- Toronto, Canada
- 2007 Infiniti fx35
Wanted to know if this will work with my FX. Really like the look of the Niche Milans
Tires will be yoko parada spec-x, 285/30R22 V
Rims are Niche Milans, 22" x 10.5", +40 Offset, 5x114.3 Bolt Pattern, 72.6mm Hub. or 22" x 10.5", +20 Offset, 5x114.3 Bolt Pattern, 71.8mm Hub (don't know what most of this means)
I plan on either getting coilovers or springs depending on what will work best with these rims
Thank you for any help as i don't know much about rims. May add other options as well
