need help running a cable to the under crarrige.
I am installing an exhaust cutout and I need to run the wire from inside the car to the exhaust . whats the best way to do this ?
through the fire wall? only way youre going to be able to do it, unless you drill a hole into the floor.
I tried and have not been able to find a gourmet that I can use to feed wire through the firewall on the FX. I cut a slit with a utility knife at the bottom side of the steering column rubber boot to feed wire through it.
Thank you LA-fx35 I used one of the grommet for the gas tank . I ran the wires all through the side plastics and even mounted the button next to the snow button . Its great I can use it when I want and then quite it down when on the highway ...
I will have one up on Monday . BTW got pulled over ( I managed to close the cutout when I saw the cop coming ) and the cop asked me to rev my engine and I did . He had a look on his face like WTF and he said I could swear your car was louder . I said no sir my car is stock you can look at my exhaust . he bent down and saw the original muffler and was baffled . I was like the car your referring to is a g35 that passed me . He gave me back my paper work and was like sorry to bother you . I was on the floor when he left the look on his face was priceless....
