What size wheel spacers for stock 21s?
i just got my 15mm/25mm spacers installed and they looked awesome!!
here's some a comparison of before and after
Looks great. Where did you get your spacers from?
Bump -
I am looking to get some mild spacers for my QX70S which has the FX50S 21'' wheels.
I am going to put 275 tires on which will help a little. I actually think the front fitment is okay as it is, but the rear needs some help.
It seems like 15/25 is common, but is a little bit aggressive for my taste. 10/20 would probably be perfect for me with stock tires, but considering the 275s will be equivalent to a 5mm spacer, I think I would be happy with 5/15 spacers. However, 5mm isn't worth doing, so I am (1) worried about a 15mm difference front/rear - will this make the rears look poked compared to the front or am I splitting hairs? And (2) will the a 15mm type 2 spacer bolt up properly in the rear?
Thanks!
Looking at these:
https://conceptzperformance.com/Cart/description.php?II=11236
On my 21's I ran 15 on the rear and then replaced them with 20mm. I have no spacers on the front.
I got my H&R spacers from zebra555.
Great, thank you! Do you have any pictures with your 0/15 or 0/20 setup?
I PMd Zebra as well. Thanks again.
Here is the rear 21" with no spacers
Here is the back with 20mm H&R spacer
Any tips for installing H&R DRM spacers? Just received my 15mm rear from Zebra (great seller, btw). Planning to throw them on this weekend. Will post pictures afterwards.
^ Thanks again. Put an H&R 15mm on the rear and it's perfect for me (nothing up front). Very happy, will edit to add pictures later.
Quick question when I had the first gen fx I had 25mm spacers in the rear and I know I needed to roll the rear fenders bc it would always catch the Back tires.. I saw some rubber ripped in the rear tires. Does this problem still exist in the 2nd gen.
Anyone running 295/40/21? I'm sure it might now need spacers but I'm just wondering who's running this setup as I know a lot of people oppose such wide tires for this rim
---------- Post added at 05:52 PM ---------- Previous post was at 07:16 AM ----------
Not*
Any one running a 275 tire with spacers? Want to get a flush look and wondering in 15 25 will be too much with the wider tire...
i just upgraded my 265 tires to 275 while still running 15/25 spacers.. no rubbing issues.. i'm not lowered so i can't say for sure if it'll rub if lowered
