22" Niche Targe M130
Without FX50 brakes, just about any wheel will fit. I see lots of 22x10.5" on eBay so it's an available wheel. Just make sure they have the correct bolt pattern. Sometimes manufacturers make a certain size only in certain bolt pattern and wheel shops may not know that and list options not available.
I was checking out some niche veronas and on the Niche site it told me there was only a 22x10. I went to my local and trusted wheel shop and he brought me out a Niche verona in 22x10.5 which was the size I preferred. He told me that some sizes are discontinued and he store some older wheels that are discontinued. by the way, the wheels look great!
Great! Good to know, thank you!
Yeah I'm pretty excited with these. Thinking of either dipping these or powder coating.
Weather condition is pretty bad up here in MN so I wont be putting them on until spring at least.
Thank you. The vendor just called me and said that 22x10.5 in the front would rub, is this the case if I'm lowered on H&R springs? Should I stagger?
What is the offset? Vendors can't know every make/model they sell wheels for and often time will quote very conservative guesses on what will fit. Staggered is fine, but the wider wheel will look better in front since it's more concave. Tire shopping is easier as well since you don't need to match staggered sizes for AWD.
So the wheels came today and the lug pattern is 5x112... on the site it says "Lugs 5x108/112/114.3/114.3" I haven't had the chance to try putting them on without tires yet, would 5x112 fit 5x114.3?
Also the offset on the box says +45
---------- Post added at 07:57 PM ---------- Previous post was at 07:21 PM ----------
So i did a little research and I guess I can use wobble nuts/bolts to make 5x112 fit 5x1114.3?
https://www.youtube.com/watch?v=33KljLVvTM0
http://www.guerillaracing.com/wobble-nuts-5x112-wheels-on-5x114-3-car-m12x1-25/
They sent you the wrong wheel if you ordered 114.3. You can use wobble bolts, but you shouldn't have to. They are a compromise and can result in shaking which is already an issue on the FX. Wobbe bolts are used if there is no other option for a particular set of wheels. Never to be used for a standard wheel like the Niche where the store sent you the wrong wheel.
so did these wheels come in 22x10.5? have you opened the box yet? you should definitely send them back.
