window go up but will not come down
mikes10fx
2010 fx35 awd
As the title says my rear passenger window will not go down with the driver side master switch but will go up with no problem. this just started 2 day ago any idea of what could have went wrong. in order to put that window down i have to use the switch from the rear door..
All the other windows working fine with that switch I take it? Does that particular button feel any different when you press it? I would start by taking that switch out and checking for any connection problems, some corrosion perhaps?
yes all the other buttons work fine and the same switch will bring the window in the back up but not down:disapointed:
Pull the driver door panel and give the window control connection a jiggle and make sure it not lose. If that not get rid of the problem, most likely the master controller is your problem.
