FX Tune ?!
Denver
2003 Infiniti FX35 AWD
Hello all,
Hope everyone had a good weekend!
I was driving down the highway and thought to myself, I want more. I need a tune.
Then I asked myself: Is that even possible?
I searched the boards and found a few UniChip threads and a couple Osiris threads. Most we're from years ago.
My question is: Is anybody still running a tune? Or know of a newer/better alternative to the UniChip Q+? Does Aaron still work there?
Background: I know nothing about maps,tuning, etc outside of what I read last night. My FX35 is stock minus CAI.
I'm looking for an aggressive tune and to help with snappier shifts.
Any input is greatly appreciated!!!
Sent from my iPad
I find myself trusting an UPREV tune (~$400-$500) over a piggy back Unichip, just my 2 cents. Tuning or adding the Unichip isn't cheap, best if you can load up on some engine/exhuast mods first and tied it together with a tune.
Since you have a 2003 FX35, the available mods I know are worthy:
1 - motodyne 5/16 plenum spacer
2 - intake that doesnt suck up hot engine air
3 - brand name catback exhaust
Search on this forum and you'll find more info/details.
Do tunes effect the engine in the long run? I mean you basically are making them run harder than from the factory so I would think so???
The tune would just optimize the car for whatever aftermarket goodies you have on it. I doubt anyone can conclusively say that it would reduce or prolong the life of an engine.
I guess you could in theory gather a lot of different data and try to generalize, but it varies so greatly based on the: quality of the tune/tuner, parts installed, different tolerances in each engine, etc. There is just too much at work to say that "A tune will prolong the life of your engine", or "A tune will lead to failure sooner".
@OP I am taking my car in tomorrow for a tune (Osiris Uprev). The shop is doing a series of other little things as well, but I should have the car back to me later in the week and I will report back on my numbers and experience.
My car ran much better with a tune. Smoother & better power delivery across entire range. Although I agree that mods will help, it's been documented that a stock setup will also show gains.
---------- Post added at 11:47 PM ---------- Previous post was at 11:45 PM ----------
rev limiter is also set fairly low on stock. you can safely raise that up to 7500 rpm on a non built VQ
---------- Post added at 11:53 PM ---------- Previous post was at 11:47 PM ----------
Just for info re. reflashing:
After exhaustive research and development on both the hardware and software, Technosquare is offering ECU flash reprogramming of flash type Nissan ECUs for racing applications and performance enthusiasts.
Current Nissan ECUs come with VERY sophisticated engine control functions, such as a constant O2 sensor feed back system and torque management by an electronic throttle control system. In another words, the ECU has complete control of the engine, not you. When it comes to performance modification and driving, these systems will get in your way, as the factory ECU is set to work best with the stock configuration of the vehicle and ordinary drivers.
When you start modifying your Nissan, you will find it very difficult to gain output by just adding performance parts. In some cases, you even lose some power and torque. Since the ECU is unable to automatically detect the modifications you made to your engine, it will still try to work within the parameters set for stock condition.
The Technosquare ECU flash changes these parameters to the specification of the performance parts installed, so the ECU knows how to behave under modified configuration and fully utilize the intended capability of those new parts.
The Technosquare ECU flash also changes the electronic throttle control setting.
Even if you push the gas pedal to floor, it doesn't mean your throttle is opening 100%.
Nissan sets the throttle characteristic for various particulars, such as torque management for drivability, or Venturi effect for faster induction and more. This is fine for the average Joe content to run his car stock, but a lot of enthusiastic drivers find it very annoying.
Technosquare puts you in control of the throttle (but still maintaining VDC or TRC features), so when you step on the gas pedal all the way, the throttle opens all the way and stays open.
As the result, engine can utilize higher flow intake and exhaust system improving (optimizing ?) throttle response.
[FONT=Times New Roman, Times, serif] 350Z TECHNOS ECU Introduction [/FONT]
[FONT=Times New Roman, Times, serif]The power of the VQ35DE has now been unleashed in the 350Z. With a strong midrange torque and the elimination of the power-lag at350z1.jpg the top-end, the Z is reborn.[/FONT]
[FONT=Times New Roman, Times, serif]The long awaited ECU has finally become available. Introducing 350Z TECHNOS ECU upgrade.
After hundreds of hours of R&D and numerous Dyno pulls, we have successfully developed this ECU, as part of a performance upgrade.[/FONT]
[FONT=Times New Roman, Times, serif]Please follow the links to find out more information about product.[/FONT]
[FONT=Times New Roman, Times, serif]Learn about TECHNOS ECU - FEATURES
How much is it? - PRICING INFORMATION
Need another ECU as a spare? - ECU DUPLICATION SERVICE
Need custom tuning for special mods? - CUSTOM TUNING ECU[/FONT][FONT=Times New Roman, Times, serif]
How to remove the ECU? - ECU Removal Instructions
How do I reset my ECU? - ECU Resetting Precedures
[/FONT]Got questions? - FAQ​
[FONT=Times New Roman, Times, serif]FEATURES:driver.jpg[/FONT]
[FONT=Times New Roman, Times, serif]REV limiter modification
A 7100 RPM (stock 6600 RPM) rev limit is set to take advantage of top end horsepower.
The stock rev limit was set way too low. Some of you may be having the problem of hitting the fuel cut at hard acceleration. We found this very annoying as we increased power at the higher rpm range. Hitting the rev limiter too often, could actually damage the engine since it is achieved by cutting fuel. By adding an extra 500 rpm, we can avoid hitting the rev limiter while protecting the motor.[/FONT]
[FONT=Times New Roman, Times, serif]Speed Limiter Removal
The speed limiter is removed. The stock limiter was set at 250Km/h (156 MPH), so for all practical purposes, we could have left it alone. But we decided to remove it, just in case someone feels the need to go beyond that.[/FONT]
[FONT=Times New Roman, Times, serif]Ignition Timing Map Adjusted
There wasn’t much room for improvement at the bottom end since the ECU retards a lot of timing by using a feed back system in stock trim. So, we have added more timing at the higher end to take additional advantage of higher-octane gasoline. This aids in improving torque from 3000 rpm and up.[/FONT]
[FONT=Times New Roman, Times, serif]Fuel Map Adjusted
Stock fuel was set to detune the top end horsepower. We discovered that the car runs extremely rich after 5000 rpm. Air to Fuel ratio (A/F) of 10.5 was found right before the stock rev limiter kicks in. Cleary, Nissan was trying to detune the power output at higher rpm to discourage the driver from hitting the rev limiter. For the performance enthusiasts, however, this is unsatisfactory, so we set the A/F to 12.5 all the way to redline to provide adequate power gain while still maintaining a safe margin.[/FONT]
[FONT=Times New Roman, Times, serif]Adding to above modifications, a few other adjustments were made to other maps to enhance the feedback function which improves power, torque and drivability. The resulting achievement is a remarkable improvement in driving feel, which is more than what numbers alone can tell you. We are very satisfied with the results and are proud to release our TECHNOS ECU for this tuning-challenged ECU, blowing the lid off what was thought to be an automobile already running pretty near its maximum capability.
[/FONT][FONT=Times New Roman, Times, serif]Our testing was done with a stock Track Model 350Z.
Gains: 10+ HP, and 8~9 ft-lbs from 3000rpm[/FONT]
[FONT=Times New Roman, Times, serif] [/FONT]350ECUtb.jpg
(Fig. Dyno-Jet result)
(Fig.Bocsh Dyno result)
[FONT=Times New Roman, Times, serif](Fig.Dyno-Jet no.2)[/FONT]
[/FONT][FONT=Times New Roman, Times, serif]Changed air intake system
One of the major problems on this car was a feedback system that compensates for modifications. The oxygen sensors detects fuel mixture and will tell the ECU to richen up or lean out the mixture. This correction factor was way too wide, so some performance components upgrades (intake, exhaust) would actually result in a loss of HP below stock!
We adjusted the correction factor to reduce that compensation reaction. Our tests showed consistent power and torque improvement following installation of an intake system.[/FONT]
As everyone said, Uprev is the way to go. More support than Unichip. Uprev also has the torque management which is supposed to help with shifting, but you may want a Transgo for that. Only other option for tuning is maybe the TurboXS UTEC, but it's been discontinued and is a piggyback.
Truly appreciate all the feedback I have received from you guys.
Anyone in particular I should speak with at UpRev that knows our cars or you all have dealt with?
How much am I looking at spending?
Yeah, I figured I didnt need a ton more mods, I heard from multiple members on other threads that my car bone stock will still see a significant difference in driving.
Thanks again for all your feedback gang.
If you're near stock, you can probably just get an email tune from them. ie, you buy the tune from their website, list your mods. Then you do a few pulls and log it, send it to them and they send you a new tune based on the log. If you look, Osiris standard has an e-tune included. If you'd rather get a custom tune, you can find a local pro-tuner who will strap your car on the dyno and flash it based on the logs. Both work and if you don't have a ton of mods, both work about the same. If you were trying to get every last hp out of it, the dyno tune works a little better since the tuner can make a bunch of pulls and play around. Getting a regular e-tune through Uprev is a little cheaper since you're not paying for dyno time.
My local speed shop (Monkey Nutz Racing, in Vancouver BC), is a pro tuner and they specialize in Nissan/Infiniti, and especially the VQ35's.
They are charging $550 for the tune that includes off-site access to an AWD dyno.
I would not pay more than about 600 for a tune, it takes less than an hour of dyno time, and the license for the tune is only like 300 bucks.
It does not take less than an hour of dyno time. I have gotten my car tuned twice now and dyno depends a lot on the maps and what you have done to the car. $550 is a good price.
---------- Post added at 01:23 PM ---------- Previous post was at 01:19 PM ----------
Hello all,
Sent from my iPad
Get all your bolt ons first then get an UpREV tune from a reputable tuner as others have stated. For snappier shifts you can go for the transgo shift kit. Install for this kit will not be cheap, but you can certainly do it yourself if you set aside a day for this job and can follow directions and be organized.
Exactly how many passes did they make with your car?
With an hour you can make 5 or 6 passes no problem. As long as you start with a decent map (for which there are hundreds for the VQ), and your tuner has a remote idea on what the hell he is doing 1 hour is a reasonable amount of time to complete the dyno portion of the tune. The rest of the fine tuning can be done on the street.
