Replacing stock horns
r3bman
Rich
I was not satisfied with the stock Infiniti horns. I decided to replace them with some louder ones, and have used the same horns on my last 2 cars and is currently on my wife's Subaru, which came with the little 'beep' horns. These are made by Fiamm, and are the Freeway Blasters; 130db at 4 inches. Pretty loud. These are the ones you want and you will be happy with these. Fiamm makes two versions of the 'AM80S' (their product number). You must get the Freeway Blaster low tone (part 72112) http://www.amazon.com/gp/product/B000DINKPQ/ref=ox_sc_act_title_3?ie=UTF8&psc=1&smid=ATVPDKIKX0DER and high tone (part 72102) http://www.amazon.com/gp/product/B000FKKOK6/ref=ox_sc_act_title_2?ie=UTF8&psc=1&smid=ATVPDKIKX0DER. You may find them at your auto parts store. I bought mine at Pep Boys. It was a little more than Amazon, but after shipping and tax, the store was only $3 more, and I did not want to wait 3-5 days. Here is what they look like.
This took me about 30 minutes, only because I had to figure out how to get to the second horn. First, remove the cover over the radiator by popping the 4 clips. If you are baller enough to have an FX50, you'll probably have more clips to remove.
The first horn is a cinch. Unplug the two connectors and use an 8mm socket to remove the horn from the bracket. One of the connectors is a clip that is held in place when the horn is mounted. This little clip will try to drop down somewhere and will be impossible to retrieve. Hang on to it when removing the horn. You won't need it, but don't leave pieces loose down there. Leave the bracket there; life is hard enough. The second horn is under the driver's side headlight.
Next you'll need a 10mm socket. Remove this screw. It is on the driver's side and connects the airbox to the inner wheel well.
Loosen the clamp on the flexible air intake from the airbox to the intake runner.
Lift the airbox up. There are two rubber grommets securing the bottom of the airbox to the car's frame. The two rubber grommets should stay in the car's frame. Lift the airbox up and over to the left so you can gain access under the headlight.
The second horn is down low. If you can grow a second elbow, do this now. If not, get your 8mm socket and somehow get both arms and hands in there. One hand to crank the socket wrench, the other to hold the horn and keep from spinning. Remember to catch the clip. This is the hardest part of the whole job. It's not bad.
Now you just reverse everything. Sorry I didn't take more photos from here. My hands were dirty and didn't want to get it on my phone. Be careful when attaching the connectors to the horn under the headlight. There is not much of a lead wire from the harness to go to the horn. You want the horn opening facing the ground so water does not get in there.
Here's what happened to me and may happen to you. Once I reconnect everything, I hit the horn button to test it. Very loud. I fire the car up, and it throws a code! P0101! The car was idling a little rough and at about 1200rpm. I look it up and it is the mass air flow sensor. I figured the MAF was unhappy after I disconnected the rubber air intake and the MAF was exposed to regular air. If you see the MAF in the airbox, don't touch it! There is witchcraft and magic in it. I got my phone and with the paired OBD II scanner, I was able to clear the code using the android app 'Torque'. Instantly the idle smoothed and dropped down to about 800rpm. I have driven ~50 miles since I cleared the code and the 'service engine soon' light has not come back on. I would recommend getting the OBD II bluetooth scanner anyways. About $12 and very handy. Hope this was helpful.
:good: Thanks for sharing. Would love a sound clip when you get a chance.
Good DIY and would also like a soundclip if you could, thanks.
Heres a sound clip I found.
[video]http://m.youtube.com/watch?v=jxwLzwrLVtw[/video]
Messing with the intake and maf might of caused the code, did you check if you connceted intake correctly?
Nice write up:good:.
Did you install the relay? If not, I would highly recommend to get one.
These did not come with a relay. It came with a mounting bracket, a few push connectors, the nut for mounting the horn, and a short jumper wire. That is probably the correct way to do it, but this is the third or fourth car I've had and done this. Have not had any problems.
---------- Post added at 10:01 AM ---------- Previous post was at 10:00 AM ----------
I thought I might have not connected the rubber air intake to the airbox correctly, but I did. I'm not sure why the car threw the code. My buddy (BMW mechanic) might tell me that a normal moron like myself should not be doing anything that would upset the MAF or other weird stuff. He'd be right, too.
---------- Post added at 10:02 AM ---------- Previous post was at 10:01 AM ----------
I will upload a sound clip. It's weird; the horns I installed on my wife's Subaru are exactly the same as the ones I installed on the FX. Mine have a slightly higher sounding tone. Not sure if it is because how sound resonates, or just slight variations in manufacture. I will get on this soon.
its still weird why it threw the code though, in the process when you had the intake or anything related disconnected, did you turn the key to the on position?
Car was off the whole time. I did not remove the connector to the MAF sensor. Only thing I can think of is when I lifted the airbox up and out of the way, the airbox bumped the top of the engine. Nothing was knocked loose, but the MAF sensor was exposed to cool air. The car had been running and was sitting for about 20 minutes before I started this little project, so the MAF sensor had warm air around it before I removed the air intake. Once the airbox was disconnected, the cool ambient air may have thrown off the MAF sensor and the car's computer may have thought there was an air leak, or the incoming air was not warm. Not sure.
One additional thing: the stock horns draw 4.5A each. It is stamped on the horn itself. These new horns also draw 4.5A, so I did not need to install a relay. The underhood fusebox has a 15A relay and a 15A fuse for the horn.
Good job
But stock rpm is not 800 at idle. It's 650.
---------- Post added at 07:25 PM ---------- Previous post was at 07:24 PM ----------
Idle relearn procedure should fix it if it hasn't itself
Thanks for sharing the DIY write-up. I just ordered both horns and will install as soon as I received them.
So, the weather was warm enough for me to install both horns pass weekend.
Boy, they are loud.
Stock:
Fiamm Freeway Blasters:
Does anyone know where I can find a horn that fits the stock locations for the horn, but plays La Cucaracha?
