Not a "direct" bolt on, but close enough. The width between the inlet and outlets is the same as the Invidia X-pipe area. So the shop just cut off the little resonators and welded this in place, then extended the pipes a little since the original X-pipe is gone too. No other mods needed. This should give you an idea of how they did it. I had originally wanted to keep the Invidia resonators to suppress sound even more, but they wouldn't clear the W brace and neither would the Magnaflow.
---------- Post added at 08:03 AM ---------- Previous post was at 07:55 AM ----------
Adding a resonator isn't going to increase drone; an incorrect one or incorrectly placed one may not do much to decrease drone though. A resonator is a straight through muffler, it can't add noise.
And Dynamat does work, but not that well for exhaust noise. My entire car is Dynmatted, mostly because I thought I was going to put a big stereo in, but ended up not. It cut road and tire noise a ton. The exhaust noise was cut a little bit, but that's not really what Dynamat does. To cut exhaust noise, you'd have to use actual foam. Dynamat just keeps panels from vibrating and won't do much for the exhaust. The weight isn't that bad, I think all in there's ~50 lbs or so of Dynamat. The FX is already slow, that weight isn't going to make much difference. It does however make the car feel slightly more luxurious since the NVH is reduced.
Drone is the result of harmonic resonance in the muffler/resonator. This harmonic is amplified in the exhaust system and manifests itself in the cabin of the car. You can add a couple of straight through glass packs (resonators) to the exhaust. Adding the wrong size resonator or putting one in the wrong place will just as likely increase the drone as well.
And whatever you do, do not Dynamat the car. It will just muffle the sound, and add weight to the car.
