BC BR coilovers offered at B2autodesigns: Great pricing
B2autodesigns
Florida
2008 FX35
Hello Members,
We are a direct BC NA dealer. Long history with them. Message me with any questions.
BC BR Coilovers package's.
03-08 Infiniti FX35/45 RWD/AWD
09+Infiniti FX
Mono-tube shock design
30 levels of damping force
Pillowball mounts and adjustable camber plates included*
Adjustable rear camber plates available
Separate Full length height adjustable
Inverted and Non-Inverted setups
One year warranty
Rebuildable
Technical
Coilovers use 46mm pistons and 53mm shock housings.
Valves are constructed of special spring steel, which outperforms stainless steels and produces longer valve life. Valve stacks use a patented deflective system to provide more precise control.
Patented concave lower locking ring, to prevent unseating
Springs are made of SAE9254 high strength, durable steel. Compression tested at over 500,000 times with less than 5% deformation
T6061 Aluminum utilized in spring locks and seats for high strength and lightweight
Iron lower brackets on MacPherson struts to ensure rigidity
Piston rods are constructed of highly polished steel to lengthen oil seal life and prevent leaking
High pressure inner rod guide seals ensure a perfect fit for consistent fade resistant damping and long shock life.
2 step coating process utilizing nickel and chromium plating to prevent corrosion
BR-Type
BC BR coilovers are $995.00 shipped to the lower 48. Comes with free extenders and custom spring rates.
Canada members add $125.00.
Package BC Coilovers w/SPC Rear camber kit w/toe bolt shipped $1079.00
Rear kit Adjustment range: Camber ±4.00 degree Toe ±3.00 degree
Please pm me or email me cback@b2autodesigns.com with any questions you might have.
Thanks
Charles
Please correct me if I am wrong, however I believe after I read your setup description, it allows for 30 levels of damping force adjustment. If this is correct, am I to understand that this would allow for dialing in a higher level of ride comfort than exists in the stock setup?
Kindest Regards
FXDADDY
These do have 30 levels of damping adjustment. These won't ride a comfortable as the stock suspension as these are coilovers. They will give a stiffer ride. Charles
do you carry these for other cars, or just Infiniti? I am looking around for 2002 Mini Cooper S (R53) (in the next couple of months)
