Where can I find the bracket where the side view mirros mounts on
Bebofx35
New york
I have an 04 infiniti fx35 and the mount part where the side view mirror bolts on was cracked some knucklehead beside to try and steal my mirror. The only thing wrong was that the bracket was crack and the mirror didn't get to be stolen any info on where I could buy it or junk yard that has one or spare parts let me know I hate how it bounces with my temporary fix thank you guys
You should be able to look I up under body hardware at infinitipartsusa.com
The mounting bracket you're referring to, is considered a part of the entire side mirror enclosure/housing, it is not offered as a stand alone part. The wiring is fed from the mirror housing directly inside if it into the car's interior.
The only thing you can try is to see if someone is selling a broken mirror on eBay and then take both apart to make into one functioning unit.
Hope that helps.
You mean the metal part in the red circle? If so, you have to get the door. I don't recall it can be separated from the door frame.
