Help: Code P0327 - Knock Sensor CEL
jmanhas
Vancouver, B.C.
Hey guys, i got the code P0327 while cruising on the highway earlier tonight, and the code came up to be a Knock sensor in Bank #1 generating low voltage.
Does anyone have experience with this code?
I didn't really notice the symptoms of lagged acceleration or anything..the car felt normal, but then again, i didn't own this car long so i don't have anything to compare with.
your input is appreciated!
You could go to the manual, engine control section, and look up this code, there should be a detailed diagnostic and troubleshooting procedure.
Sent from my iPad using
Its common to finish knock sensors cracked or broken. I've seen this happen many times. Older VQ have them mounted in the valley of the V under the intake manifold. I don't know if the 3.5 is the same. I would physical inspect the sensor and possibly the harness.
Knock sensors when triggered retards ign timing and in most make ur car a little slower. Might be hard to noticed sometimes.
Sent from my SGH-I337
+1. Replacing the sensor usually fixes the problem. Under the intake as TurTLeG has noted.
