STIBungy
- Denver, CO
- 2007 FX35 AWD
Hi guys,
I did a search on brake bleeding and didnt find a whole lot of info on it other than 1 person who had a dropped brake pedal.
Anyhow, decided to bleed my brake system tonight as one piece of troubleshooting why my front rotors warped so quickly.
The story on my 07 FX35. I bought it back in July. Brakes were warped and I drove it like that for a couple of months. Then I ordered some OEM pads and slotted front rotors off Ebay. I didnt install them yet but decided to take the existing rotors and have Napa turn them. Installed them back in and they were warped again. I figured maybe they didnt turn it properly. I then installed the new Ebay rotors along with the OEM front pads. Read the instructions on bedding the pads by going up to about 40mph or so and braking fairly hard to nearly stop and then repeating that several times. After about 3rd or 4th time, I noticed the infamous steering wheel shake again...@#$^! Even after the first brake to a stop, I didnt have a good feeling about it.
I was hoping that there was some air in the rear brakes causing the fronts to overwork, thus overheating the front rotors and warping them. No such luck. No air on all 4 calipers.
One thing I noticed was that the rear bleed screws are different size than the fronts. The fronts required a 10mm wrench while the rears took an 8mm. Also, the nipple sizes are different between the fronts and rears. Kind of annoying to have different sized bleeders between front and rear.
Thanks goodness for my Power Bleeder. That made brake bleeding go alot faster. :D
---------- Post added at 10:04 PM ---------- Previous post was at 09:29 PM ----------
Here are some pics I took:
Front caliper bleed screw:
Rear caliper bleed screw:
Power Bleeder:
Power Bleeder:
