I was always told the opposite, which I believe is the proper way, and that is "the car should be sitting on the ground and level when you install a front strut tower brace."Interesting? Handy Andy did you know that we should had probably lifted the front car up instead of trying to bend it forever? lol
Brackets first, but I don't think washers are appropriate - won't it give the brackets too much "give" making the STB less effective? Neva I'll be around dec 15ish if you want a hand… I did mine in my school parking lot with the wrong tools and got it done in about 45 min by myself after a little trial and error. haha. Maybe we can see if my tune on friday actually does anything but increase #s too
Washers would only be used if the brackets didn't seat flush. It's not perfect, but better than having a gap between the bracket and strut tower.
The thing is there shouldn't be washers between the brackets and the towers. The bracket is incorrect and should be replaced. Gtspec obviously did not do their research properly and fabricated a flawed product that deviates from their intended purpose.
The issue I have is not with how I'm putting the bracket on but more of it not being designed to not create a bridge over that hump near the strut tower.
I wish stillen made a strut bar, they would never allow this major flaw
Sent from my SGH-I747
there are bound to be some differences in GTspec's metalwork - we already know they buy and relabel from a generic manufacturer (summit racing uses the same and is cheaper) so it's expected that there will be some deviations from exact measurements.
What i'm wondering too is when you get an alignment done on the front end, don't they lift the car off its wheels and then adjust? If so, then I would think the bar would be best bolted tight when its raised...
What torque setting are you guys using for the nut/bolt that holds the bar to the bracket?
The washer solution was not enough on my 09, Besides that I still had to grind some off the bracket. Just make sure you can make full thread contact with the 3 nuts.That's true. Well GTSPEC messaged me back and stated they can exchange the strut bar but what we agreed on is that they will bring in an FX35 and test fit the bar and take photos. If they see an issue, they will take it from there. At least they are taking the first steps in looking into this.
The washer solution hopefully lifts the brackets high enough, though wouldn't want to grind the bracket since its not that thick. I'm just worried its going to sit too high and hit the hood.
Sighs..products shouldn't be like this...
If what I hear has any truth to it, then GT Spec doesn't make their bars and braces anyway, the bars are made by someone else and GT Spec is just rebranding them. If their manufacturing process is out sourced to another company than complaining to them probably doesn't make much sense because they can only replace the brackets with more brackets built the same way.
---------- Post added at 01:00 PM ---------- Previous post was at 12:58 PM ----------
+1 Lol you beat me to it.
---------- Post added at 01:14 PM ---------- Previous post was at 01:00 PM ----------
Since a few IS members said they also had to bend the bar a little, do you guys think if I lifted the front wheels off the ground then put the bar in place and lowered the car slowly, it would eventually line up as I lower the car? Or do I have the concept of preloading the bar a little confused?
I understand the purpose of preloading the bar but then wouldn't that mean what I'm asking will work?
