Wheel Spacers
my front shakes like crazy at 60 mph and up.. even after rebalance and alignment.. had 20mm on all fours but ended up removing the fronts.. aybody else have problems the "shakes"?
^ your wheels shook because of the spacers? That's weird, I didn't run spacers on this vehicle but I have had spacers on previous vehicles and never had shakes due to spacers. Might be the spacers you are using
If you have quality hub-centric spacers you should not have any problems.
If you bought Ebay cheap-o spacers thats your problem.
I installed the 27mm all around, i'm pretty satisfied with the look. As far as it runs so far so good, not sure if it needs to be re torque as per my mechanic though. I might just end up asking meme405 to help me re-torque it as he has the torque wrench. :ninja:
