DIY axle fix
I think OP is looking for DYI to replace the front drive shaft/axle since his boot got a pin holes from read his other posts.
^there is a front axle diy on g35driver.com its mixed with into a front wheel bearing diy.
But its just the same as any fwd CV axle. Bust open that axle but which is a 30/32/36. Push the axle out of the knuckle, loosen tie rod end off knuckle and pop out of front diff.
Its highly DIY or if u were trying to reboot it u don't need to pop the axle off the front diff.
Sent from my SGH-M919 2
thanks guys, what does OP mean?
---------- Post added at 09:58 AM ---------- Previous post was at 09:57 AM ----------
Andy, have you been getting my private messages?
Yes, I got your PMs. I preferred to share my responses on here since you've been posting the same question here.
